Re: Super C stalled with pictures
Posted by Janicholson on April 07, 2011 at 20:12:18 from (64.61.211.178):
In Reply to: Super C stalled with pictures posted by Dean Olson on April 07, 2011 at 19:55:37:
Pull the spark plugs. use the old cap and make a pressure adapter to put 7psi in the system (or a pressure tester) then wait for about an hour, keeping the pressure up if it leaks off. Then crank it over watching to see if water is getting into the cylinders, and which one. If none, Run it with the new cap and see if it still does it. It could have had the thermostat sticking. Jim
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
