Thanks again. Sounds like what I'll do over the next few days is pull the rocker arm and set it aside, then pull the head and take it in to have checked. They could probably do a straight edge on it at the same time to see if it's warped, etc. Can't cost too much for that and it'll get be going in the right direction.
Not sure what I'll be up against if I find the head or block cracked.....
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
