It has been a while but I think you pretty much have to pull the rocker assembly to pull the head off but after you have the head off there is no reason you could not bolt it back on hand tight would be all that was needed to keep things together. Also if your just going to let it sit that way I would put a bunch of ATF in the cylinders and lay the head back on just to keep it clean, But if it was me I would leave it together till you have the $$ then open it up. I would still fill the cylinders with ATF and make sure the radiator and block are drained
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
