Posted by El Toro on January 20, 2011 at 12:12:56 from (108.3.200.96):
In Reply to: BACKFIREING posted by JEFF NC on January 20, 2011 at 10:27:48:
What did you set the valves at? Open that main jet adjusting scr/w near the bottom of the carburetor. Your plug wires need to be in this firing order on the cap. Your battery doesn't supply voltage to a mag unless you converted it to a distributor. Hal
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
