Posted by JEFF NC on January 25, 2011 at 12:43:07 from (67.213.44.176):
In Reply to: Re: BACKFIREING posted by El Toro on January 20, 2011 at 12:14:33:
I HAVE A MANUEL FOR THE H AND IT SAYS THE FIREING ORDER IS 1 3 4 2. IS THIS NOT RIGHT? I DID SET THE VALVES AT 20,000. ALSO I HAVE ADJUSTED THE SCREWS ON THE CARB STARTING AT 1 AND A HALF TURNS OUT . THEN IN AND OUT. NOT MUCH DIFFERENCE IN THE WAY IT RUNS. IS IT POSSIBLE ITS NOT GETTING ENOUGH FUEL THROUGH THE LINE? IT SEEMS TO BE MOVING A LOT OF FUEL.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
