Posted by William Ransom on August 11, 2010 at 14:58:11 from (65.167.44.85):
In Reply to: Re: M magneto trouble posted by Tom Fleming on August 11, 2010 at 14:30:10:
The contact on the rotor does not appear to be adjustable. I don't think the wires are resistor wires. Whatever kind of wires they are, the coil wire and three of the spark plug wires are from a 1970-something Chevy pickup truck, and I think the fourth spark plug wire might be one of the tractor's original spark plug wires -- at least, it's painted red and was used on the tractor in the 1980s. I got it to run with the coil wire and spark plug wires that are on it now in 2003-2006.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
