Posted by Tom Fleming on August 11, 2010 at 14:30:10 from (206.193.253.243):
In Reply to: M magneto trouble posted by William Ransom on August 11, 2010 at 14:18:39:
What type of wires are you using? Are they copper core? Also, what type of rotor do you have? Is it the newer style, with a set contact, or the older style, with an adjustable contact?
If you wires are not copper core, replace them. Mag's don't like resistor wires.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
