It sounds like you have removed all vertical travel from your upper bolster shaft and the gear is tightened against the housing at the upper bushing. The spacer (shim) at the thrust bearing should allow at least .005" of end play when the gear is tightened down.
My '51 H bolster and shaft were worn badly enough to require nearly 1/4" thick spacer. To get a good measurement for it, I put it all together as if it were the final assembly. The nut was tightened to line up the cotter pin hole and the end play was measured with a dial indicator. Subtracting .005" gave me the value to make the spacer.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
