My spacer removed excessive vertical play and went right under the thrust bearing. There is nothing under the gear. I see now that the shim you were describing removed excessive clearance in the bottom bore of the bolster housing. That is good.
The reason I put the spacer down below instead of under the sector gear was to have a better fit of parts. Plus, down there all the parts moved together so they wouldn't wear against one another. If the spacer is under the gear, it will always be rubbing against something every time you turn - either the gear, the shaft, or the housing.
Today's Featured Article - Tractor Profile: Silver King - by Staff. Silver King tractors were produced by the Fate-Root-Heath Company of Plymouth, Ohio. The company was founded by John Fate in 1884 and was originally called the "J.D. Fate Company". After several mergers over the years, the final company name of Fate-Root-Heath came about in 1919. The first tractor produced was actually called the "Plymouth" tractor and was powered by a 20 HP 4-cylinder engine with a 3x4" bore and stroke. The four speed transmission had a top speed of 25 mph! After more t
... [Read Article]
Latest Ad:
[More Ads]
