Posted by dougct on April 12, 2010 at 13:38:16 from (71.234.250.61):
In Reply to: Re: C timingpicture posted by teddy52food on April 12, 2010 at 07:51:20:
Teddy,I have a H4 mag and when I took off the plate those 2 gears had no such markings,but in the end,when the mag snaps,the rotor should line up with its cylinder contact?Right?Because mine was snapping before the matching contact.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
