Posted by teddy52food on April 12, 2010 at 07:51:20 from (209.237.115.177):
In Reply to: Re: C timingpicture posted by dougct on April 12, 2010 at 05:07:20:
After the rotor is off, there are 3 screws to remove. Then you can check and or replace the points too if they are bad. Take the 2 small screws off the plate where the large gear is. On the small gear there are 2 teeth with the edge milled off. those should match up with the C mark on the large gear.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
