There is an extra screw on the delco remy light switch, it is to the right of the rear light screw, and one front headlight wire is attached to that screw, the other front headlight wire is attached to the screw next to it. The tail light wire is attached the the lower head light screw. there is no resistor to the screw just above the headlight screw.I think maybe I should buy a light switch from ebay and hope it is more complete than this one!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
