Use of fuel additives in old tractors
Posted by Gale Roberts on March 27, 2008 at 12:10:38 from (205.188.116.73):
Is it necessary to use fuel additives to take the place of the lead in the unleaded gas we get now days? I have been told the old tractors designed before unleaded gas was used will have a problem with the valves recessing into the head or block depending on if they are overhead valve type or valve in block type unless harder valve seats are installed or lead additives used. If additives are required what do you recommend that I use. Advice on this will be appreciated.....Gale
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
