I do not agree he has a low compression problem . It wold not be the first time a machine shop messed up. If the valve heads do not stand out to the correct hight then you have a low comperssion problem . And never have i had a problem liten off a diesel like he has and NEVER have i had to use either . Not even a Detroit . On his engine the valves have a resession of .039-.055 on the intake and if it is over .120 ya have a problem and on the exhaust it should be .047-.063 and here again no more then .120 . Also according to my books here depending on engine S/N there are two different pistons and also a option for high compression pistons . SO i stand my ground on the low compression.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
