Michael, you can check for coolant leaks but my guess is you will not find any. Those German Diesel require a break in period to seat the rings like Janicholson said. My Dad had same experience with 454 D179 about 20 years ago. Required about 10 hrs. of hard work to break the engine in and stop white smoking.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
