Posted by Jamie Farmall on March 21, 2008 at 19:58:19 from (66.35.105.172):
I have an H Farmall that has an F 10 Loader that I use for light duty work & snow removal. Last summer I went to move it and it developed a rattle or grinding noise in reverse. I shut it down. I drained the trans fluid & put new in (this had not been done in a Loooong time!) and drove it around a bit in low gear. The noise went away. It stayed gone until recently when I ran it in 3rd rather than low. It returned. Then it stopped. Before I could diagnose the problem (have someone listen to it), it came back really loud while it was in neutral & sitting still and the tractor died. With the clutch in you can start and run it but if you try release the clutch it dies. Any idea what went wrong???? Or.....does anyone need a good running H engine and a wide front??? Please help.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
