The only thing you don't have on your list is patience. I have a very similar set up, but with more electrodes around the side. Adding more washing soda is not beneficial, your mix is correct as is. As the water lowers, add more water to bring it back to the proper mixture.
I’ll leave large items in the tank for four to five days and then hit it with a pressure washer. All paint and rust will fly off!
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
