I used this method to clean parts on my Super A and it worked well. The electolysis attacks rust so if there is minimal rust under the painted surfaces there will be minimal impact, other than the washing soda working its magic on the paint.
The process will help in loosing rusted bolts. As the part sits in the tank it doesn't appear to change all that much, but when you remove the part, clean with water, and hit with a wire brush it will clean up real nice. Most of the rust around the frozen bolts will easily be removed which will allows your favorite penetrating oil to get to the levels required to break free the stuck parts.
On deeply rusted parts I had to cook for a few days, clean the part with a wire brush, clean the gunk off the anode, and cook overnight again.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
