Well it was bought as an F-20 so I can't say for sure. Are they interchangeable? This one bolts right up. As for the governor tube support I have a separate piece that bolts to the tube and the left hand nut on the manifold. Everything bolts up including the carb and the exhaust tube which has a cast flange. But this is the reason I am asking and gave the cast number.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
