As for the governor tube support I have one but it's a separate piece that bolts to the nut on the left of the manifold. It does look similar to the F-30 manifold with the exception of the height of the flanges. The one you pictures looks like a single nut and washer would suffice to hold down the flanges whereas mine is higher on one flange which would require a hold down such as the 2 that were on the original manifold. The 2 that won't fit on this one. Heck if I know.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
