Posted by leecramsey on September 20, 2007 at 17:13:06 from (204.155.56.3):
In Reply to: Power Steering on '41 M posted by Jamie Larson on September 20, 2007 at 16:19:59:
I put an M engine in my 400 temporarily and added the power steering back to it. When I got it all bolted together, the fan hit the pump mount. I checked the old fan on my 400 and it was made with a different spacer on one side of the fan tesioner. When I changed the tensioner it moved the fan out to clear the pump housing. It moved forward about 3/8 if I remember correctly. You may have to find a different fan assy. I can't remember if the spacer was removable. Hope this helps. Lee
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
