Posted by Jamie Larson on September 20, 2007 at 16:19:59 from (208.53.229.235):
Grandpa's M had a charlynn power steering unit on it. I have rebuilt the motor and the water pump was shot. I got another from a neighbor fan and all, so I tossed the other. The fan grandpa had on it was obviously not from an M and had been cut to fit in the shroud. There was also much less pitch to the blades. With the new fan and water pump the fan hits the power steering pump belt. What do I need to do to correct this? Extending the fan forward with spacers does not seem to be an option as then the drive to the water pump will not work. Any ideas will be appreciated.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
