Hi, If it has a 12 volt alternator then it would have been changed to a negative ground. That would be the most likely, but if someone put a 12 volt generator on it, more than likely it would be positive ground. An alternator will be almost ball shaped with an alluminum finish. A generator will have a cylinder like shape with a painted steel finish. Also look at your battery cable ends, one should have a larger hole than the other, just like the positive post on the battery is larger than the negative. Good luck, Chuck
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
