Posted by FarmallAK on August 27, 2007 at 20:00:19 from (24.237.149.57):
I took the bad battery out of my 1940 Farmall H, without noting whether it was hooked up to positive ground or negative ground. The tractor has been converted (not by me) to twelve volt system. Is there a way I can tell which way to hookup the new battery without damaging anything? I am not very knowledgeable with things electrical. Can anybody help an electrical dummy? I just don't have a clue about how to tell which way to hook the new battery up. Thanks so much for any and all help.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
