One way toget it, is the positive post is just a bit larger than the neg post.So the big end cable goes on the big post.
If you didn't distort your ends to much you can tell that way.
Another way is the post are set off to one side of the battery. Try to remember which side of the box they were on when you removed the battery. Then see how the cables best reach. Most times the ground will not reach to the other post.
I'm sure there's a technical way to tell also, but I don't know it.(:~})
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
