calculating voltage
Posted by hassan fortney on January 11, 2006 at 22:11:03 from (12.215.74.246):
there seem to be a lot of questions about voltage and the mystery surrounding voltage.
ohms law
Ohms law ca be expressed as an algebric equation: E=IxR
"E" = electromotive force (voltage)
"I" = intenstiy (amperage)
"R" = Resisance (ohms)
there is an equation to see the various relationships between amps vlots and ohms.
if you know the voltage and the resistance you can figure out the load on the given circuit.
say like like converting from a 6 volt system to a 12 volt system and you want to know the proper wire size for the headlites. for headlites you use watts instead of volts in the formula to find the resistance and go from there.
the formula:
volts = amps x ohms
and or amps= volts/ohms
and or ohms= volts/amps
or E
I|R
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
