calculating voltage
hassan fortney
01-11-2006 22:11:03
there seem to be a lot of questions about voltage and the mystery surrounding voltage.
ohms law
Ohms law ca be expressed as an algebric equation: E=IxR
"E" = electromotive force (voltage)
"I" = intenstiy (amperage)
"R" = Resisance (ohms) there is an equation to see the various relationships between amps vlots and ohms.
if you know the voltage and the resistance you can figure out the load on the given circuit.
say like like converting from a 6 volt system to a 12 volt system and you want to know the proper wire size for the headlites. for headlites you use watts instead of volts in the formula to find the resistance and go from there.
the formula:
volts = amps x ohms
and or amps= volts/ohms and or ohms= volts/amps
or E --- I|R
rif
01-12-2006 13:50:58
 Re: calculating voltage in reply to hassan fortney, 01-11-2006 22:11:03
you are talking about two different things here.
ohms law and power(watts)
watts is = to volts x amps
(ie) 6 volts x 20 amps =120 watts 12 volts x 20 amps =240 watts
what you need to determine is how many watts the lights are, then divide by 12 and that will equall the amps needed to run the lights.
the size of wire you need will determine the amps that can flow through the wire. I think a 14 gauge wire can handle 20 amps of current.
hope this helps,
dave
hassan fortney
01-12-2006 14:49:07
 Re: calculating voltage in reply to rif, 01-12-2006 13:50:58
yeap rif you are right!!! over sight on my part.
Power is the name we give to the rate of work done by any sort of machine. power consumption is expressed in watts. one tid bit of info
746 watts = 1 hp
an eletric motor can be figured this way.
the first solving circle is E
----- -- I | R
second p= power or watts is
P
----- --- I | E
or P=IxE
chadd
01-12-2006 08:02:34
Wow, what are the odds. I just walked out of Linear Circuit Analysis class in college, sit down to eat lunch, and I get a review session! We learned Ohms law about 3 weeks ago. Great overview of it. I'm sure a lot of people will find it helpful.
old
01-11-2006 22:23:30
But whats E=MC squared mean LOL. Just kidding. Even if it has been years since I needed it. Sure wish I could remember all of that stuff but I haven't used it in close to 20 years or so. I usto know how to count in base 2 and base 8 also but again haven't needed it so I don't think I could any more. I even at one time knew how to program computers but that was 20 plus also
hassan fortney
01-12-2006 06:02:46
 Re: calculating voltage in reply to old, 01-11-2006 22:23:30
it seems like alot of einstiens therory and stuff.
and wow old youre old!!!!
haha just kidding.
yeah for some guys calcuating voltage can be done in your head which I sure you probly already can. I thought I put this up there for the guys who could benifit from this formula.
to be honest I dug the info out of a book that I havent looked since college over 10 years ago yes yes I am not old. lol.
old
01-12-2006 07:32:00
 Re: calculating voltage in reply to hassan fortney, 01-12-2006 06:02:46
Well since I have worked as an ET, mantance eletrition etc I remember a rule of thumb thing about wireing things up. Plus even if that rule says #14 wire I use #12 instead, I don't like to gamble when it comes to ZAP-U-TRONS LOL
