Re: OK, now I am starting to get confused......nee
Posted by Bob M on November 04, 2004 at 07:09:08 from (165.170.128.65):
In Reply to: OK, now I am starting to get confused......need he posted by Brian in NY on November 04, 2004 at 06:07:26:
Brian – A couple thoughts: 1 – Are you overfilling the radiator? On my SH and SM if the coolant level with the engine cold is higher than about 1” from the bottom of the filler neck they’ll spit out the extra coolant when the engine heats up. 2 – The belt tension is certainly contributing to the problem - the loose belt causing both the fan and water pump to spin too slow. I had the same problem with the adjustment set screw on my SH (screw snapped off flush with the hub when I tried to loosen it). I got the busted end out by using an arc welder to build up a “nub” on top of the remaining portion of the screw. Then grabbed the nub with vice grips and the busted end turned neatly out. Apparently the heat of welding loosened whatever was holding the screw. Note: I replaced the set screw with a stainless one and coated the threads with Nevr Seez so as to not have the problem again! Note that both my tractors tend to run hotter - as indicated by the temp gage - at idle than at speed. I presume this is on account of the low air flow thru the radiator at low idle and may be normal?
Home
| Forums
Today's Featured Article -
A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
