OK, now I am starting to get confused......need he
Posted by Brian in NY on November 04, 2004 at 06:07:26 from (24.97.78.198):
I have been putzing around with an H I bought this past summer. I have another H and a B. I am not a restorer, I use the tractors and fix them when they break. This new H is confusing me. The serial tag is somewhere around 360000 (can't remember exact off the top of my head) and from that exact # I have found it to be a 51 model. It is a gas, not dual fuel. Well, as some of you may remember this sucker has been heating up intermittantly on me. It has been blowing antifreeze out the top of the radiator. The tractor has a water pump, but it does not have a pressurized radiator (the gas cap is the same size/fit as the radiator cap.). This type of system does not seem to jive with the tractor being a 51. Should have a pressurized system on it, right? What kind of problems am I going to have with a mixed up system? Or is it not uncommon to have this set up? In my investigation into the cooling problem, I found that the belts were kinda loose. I marked the belts and the pullys and ran er, and the pullys are spinning faster than the belt. Problem is, the set screw that allows you to tighten the belts is busted off (I didn't do it!) I am afraid to use an extractor in that location, due to prior bad experience with extractors. I really think the belt tension is the problem, because at road speed, she don't heat up a bit, nor spill out any antifreeze. But when I am idling around my property she spits that a/f out through the overflow tube in a constant stream. There is no bubbling in the radiator when it is running. I gotta get this old girl runnin good before it snows heavy...my other H is loaned to my brother in law for the winter to plow with, and the B, well it will move a bunch of snow but it takes a LOOONG time. Any thoughts? Hope my questions are clear but if not let me know.
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
