Re: Farmall Cub oil pressure problem
Posted by Bus Driver on May 31, 2003 at 14:41:58 from (65.165.153.2):
In Reply to: Farmall Cub oil pressure problem posted by Gaetan in QC on May 31, 2003 at 07:22:02:
Prime the oil pump. Not an unusual happening on a Cub when not run for extended periods of time. On the left side of the engine at the back of the block- in the edge of the flange- hidden under the hydraulic lines if you have them- there is a small Allen head plug. Remove the plug and using a pump oiler, pump the hole full of the same oil used in the engine- requires very little. Reinstall the plug. Avoid running the engine without oil pressure.
Post A Followup
: Re: Re: Farmall Cub oil pressure problem
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
