Re: Re: Re: Farmall M electrical system
Posted by Larry W. on April 24, 2002 at 06:13:34 from (216.228.37.151):
In Reply to: Re: Re: Farmall M electrical system posted by Lee West on April 23, 2002 at 20:35:03:
Does it have an alternator? If it does, it has to be negative ground. If it has a generator, and battery ignition, look at the top of the coil where the two little wires hook up. one wire comes from the dash, and one comes from the distributor. If the one from the distributor is hooked to the negative post on the coil, it is negative ground. If you still have a magneto, I can't help you.
Post A Followup
: Re: Re: Re: Re: Farmall M electrical system
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
