Farmall Tractors Discussion Board
Re: Stupid H question
Posted by The Red on July 27, 1999 at 11:39:18 from (206.246.187.2):
In Reply to: Stupid H question posted by Weekend Farmer on July 27, 1999 at 11:12:11:
That ain't a stupid question. You can get new PTO seals from Bermuda Ken. I suggest you get two and also a new seal base gasket.
H takes 6 gallons of 90W or 85W140. To check, there is a nut on the clutch side. If fluid drains out then you got enough. It is in front of the pedal just before you get to the clutch housing assembly.
That BIG OL NUT just right of the steering post and underneath the control panel is where you fill. Just left of the left brake pedal. Use a 3/4 inch rachet head to unscrew it. You might want to clean around it first. It attracts dirt.
Post a Followup
: Re: Re: Stupid H question
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
