Farmall Tractors Discussion Board
Re: Oil Consumption
Posted by RK Smith on April 20, 1999 at 05:47:56:
In Reply to: Oil Consumption posted by H Fan on April 20, 1999 at 05:34:55:
6 quart capacity, from the shop manual, and the oil is most probably "extra" dirty from "blow-by" around the rings, and the oil consumption is probably from the same thing. The "age old" decision is when to tear down and do a ring job, which with an old tractor I would never recommend unless you planned more extensive work. Dirty oil blows by the rings easier, so try keeping the oil changed more often, and put say "one or two pints" of STP oil treatment in. All it does is thicken the oil slightly, making it about a minimum 35-40 weight. Make sure your coolant is fresh and watch the temp. Baby the old engine and you may actually get years of light utility out of it.
Post a Followup
: Re: Re: Oil Consumption
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
