Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Re: Oil Consumption
Posted by RK Smith on April 20, 1999 at 14:03:41:
In Reply to: Re: Re: Re: Re: Re: Oil Consumption posted by H Fan on April 20, 1999 at 12:01:24:
sounds like you're "hell bent for leather" to work on something. OK, have fun. This might give you some insight into the valve guides. Operate the H til warm, then at about 1,000 rpm, quickly throttle up to max. Observe for blue smoke. Now idle down to "dead" idle, barely running for about a minute at least, then throttle up to max. If you get a rush of blue smoke the second time, after the low idle period, but not much the first time, it may be a good sign of worn valve guides. At low idle, there is less neg pressure on the head and oil will collect over the valve guides. At higher rpm, the pressure increases and sucks the oil past the guides. At the higher beginning rpm, there is less pooling of oil, then less blue smoke at throttle up.
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Oil Consumption
Today's Featured Article - Repairing A Massey Harris 22 - by John Reeves. I have just given this old girl (boy?) a replacement RH rear axle. I was lucky enough to find an axle in good shape at a reasonable price - also a replacement for the right rear brake assembly which was ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
