yah that sound like a good idea they will slide out the bottom past the crank so all i need to do is drop the oil pan and take off the caps and pull the pistons out or is there more to it than that think there is any chance it will fire up with out doing that not to be lazy but some times i dont know when to stop you know how that can go sleves,bearings,seals,and the list would go on thanks
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
