Dan, it won't take much money to a better job, just time, this is what I did, free up the engine, remove pistons from bottom, keep track of shim count for each piston, number each piston with a arrow towards the fan or front, hone each cylinder completely, put in new rings from Alderson tractor parts ( about $24. each ) or use your old ones if you don't have the money for the rings, just remove them gentley and clean ring grooves, reinstall, these motors only spin 1150 rpm, they are not a nascar engines, you'll be surprised how nice it will run with freed up rings as well, don't forget to evaluate valves while head is off,
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
