Re: HELP, The Farmall C I purchased a couple months ago OVERHEATS
Posted by Red Dave on May 06, 2001 at 12:58:43 from (64.41.23.153):
In Reply to: HELP, The Farmall C I purchased a couple months ago OVERHEATS posted by Kurt on May 05, 2001 at 18:30:04:
If the radiator is full and you get the motor good and hot, it's normal to lose some out the overflow, but 230 deg sounds too high. I would flush the system good and replace with fresh coolant first. Be sure to mix the antifreeze and water before you pour it into the radiator. Before I'd pull the head, I would take the radiator to a shop and have it boiled out first. If it doesn't have a water pump, it probably won't have a thermostat. The radiator must be full for the thermosyphon to work. If all else fails you can add a water pump, this was done to a lot of C's.
Post A Followup
: Re: Re: HELP, The Farmall C I purchased a couple months ago OVERHEATS
Today's Featured Article - Restoring a John Deere 2010 Diesel Tractor - by Jim Nielsen. Following seven years working in California's Silicon Valley, my wife, baby son and I moved back to Australia to retire. We bought a small 'farm' of about 50 acres near Bendigo, in the state of Victoria. I soon found that it would be very useful to have a tractor around the place for things such as grading our long drive and brush-hogging the fields. I was also embarking on planting 1000 eucalyptus trees, and hence I would need a ripper, small disk plow, sprayer etc. to get these things accompli ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
