Re: Lots of Questions about head gasket change.
Pat
01-16-2003 12:23:50
Hi Shane, The Fordsons actually have a engineered blockage in the oil ports to the head. The camshaft has a port cross drilled into the center bearing, once every revolution when lined up with the ports in the block it allows a squirt of oil up to the head. If the rocker shaft is wet and a little oil is flying around when running its OK. If it is dry get back to me.
