Re: Broken shut off cable on Super Dexta
David
04-27-2002 01:16:30
Don,
My solution was to use a bicycle brake cable (casing and inner). I reused the existing stop knob by cutting off the broken cable where it entered the 3" steel rod. I then drilled into the end of the rod. After careful cleaning, silver brazing alloy was used to attach the new cable in the hole. A new piece of casing looked a treat. (still in service 4 years later)
(245 grade silver brazing alloy, the one with 45% silver and a little cadmium (NOT the 5% plumbing stuff) works well on steel and can be used with a propane torch .. small one for this size).
All the best.
