Re: Dexta engine temp
Mark Burgess
08-04-2001 19:58:53
Hey Ed R if I was you I wouldn't take any chances with my engine. I would take the radiator out of the tractor and have it's flow tested. That is to say how fast the water runs out after it has been filled. If it is to slow then it needs flushed. It's not much of a job and shouldn't cost much, and also if you have this done be sure to have it pressure checked to make sure it doesn't leak. I did this to mine and I had a small leak. Also check and see if your water pump is working up to par. Take care
Cappy
