Re: Dexta Hyd.
Burrhead
12-16-2000 18:09:38
Ford recommends 80W gear oil, but if you are in cold country 30W or 50W oil is fine or even normal hydraulic oil if it's severely cold there where you are.
Over just forward of the pto lever and a few inches above the left foot board is the check plug, you take the plug out and use a gear oil pump to fill it til oil runs out this hole, it's just like filling a car rearend. The differential and hydraulics on a Dexta share the same oil reservoir.
If you don't have a oil pump here's the other easier way.
Standing behind the tractor looking forwards at the differential there is a big plug just to the right rear behind the seat. Pour your oil into this plug hole until oil pours out the side plug hole.
Congrads on your new tractor and good luck. There are several folks around here who know a little something about Dextas and we like to see them still going.
Butch
12-16-2000 18:25:38
 Re: Re: Dexta Hyd. in reply to Burrhead, 12-16-2000 18:09:38
Thanks a lot Burrhead.
I live in the interior of BC Canada and it has been about -28 C. about -18 F.
I have some hyd oil AW 46 here so it should be allright eh?
Burrhead
12-17-2000 15:50:46
 Re: Re: Re: Dexta Hyd. in reply to Butch, 12-16-2000 18:25:38
You'r welcome Butch.
This site must have crashed last night. I've been trying to answer you all day so maybe it will work this time.
The hyd oil will do fine. One more thing you might want to do is be sure that the air cleaner basin has winter oil in it too. In cold weather the reg weight engine oil in the breather will smother the engine sometimes.
