Re: FMD w/Sherman backhoe-loader questions
Ronald Sollome
10-22-2000 15:42:52
Dear sirs; i own a 1954 800 ford tractor, with a sherman back hoe and front loader.i purchest it from a farmer who abused it. (the backhoe)i rebuilt the pump and started it i rember screaming its alive my first backhoe. since the tractor was in reasonable shape, good engine and front loader. i need it for work around my horse farm i've let my neighbor borrow it several times and he always blows the pump.we went to test the pressure and saw it was at 2500 psi tryed lowering it to 1500 and started at 500 and then 1000 and then it went to 50 psi tested just the pump then and still had 50 psi he thought the pto went so i removed the pump and gear box and the pto turns stongly would the small seal at the end of the pump(cessena) cause low pressure or is there another problem it worked befor and am sure it will work again. just stumped i,ve replaced the center plate cause of a crack each time he uses it and breakes the pump the center plate is fine but no pressure please contacte me at e-mail above thanks ron
