Re: Re: Re: Re: Re: Re: Re: Dexta clutch.. fixed!
Burrhead
09-21-2000 11:55:57
Most of them I have checked run around 175 to 200 tops.
Gary
09-28-2000 17:56:54
 Re: Re: Re: Re: Re: Re: Re: Re: Dexta clutch.. fixed! in reply to Burrhead, 09-21-2000 11:55:57
On the Dexta, I used to get alot of black smoke, even at idle. The problem was the diaphragm in the injector pump. It had a hole in it and thus was giving full fuel at all engine speeds. Bought a new one at the local diesel injection shop. Cleared up the smoke and cut wayyyyy back on fuel consumption. How do you check the compression on the diesel engine? Where do you connect the guage to?
Burrhead
09-29-2000 13:04:18
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Dexta clutch.. fixed! in reply to Gary, 09-28-2000 17:56:54
You have to take the injector out and use the rubber tipped auto type gauge into the injector hole, just push it as hard as you can into the injector hole and hope for the best.
