Fordson Tractors Discussion Forum
Re: Fordson Dexta Fuel Lines
fatbob50
10-03-2007 20:55:26
That line from the manifold is for cold starts. If it is not hooked up, then you do not have the original shut off valve under the tank. The original shut off valve has a connection so that the cold start aid connects to it. The shut off valve probably went bad and they replaced it with one for a regular Ford 2000 instead of a Super Dexta. The Dexta valve is around 75.00 from a dealer and the shut off valve for the Ford 2000 is around 12.00. Hope this helps. Bob
Walter Allen
10-04-2007 04:41:10
 Re: Fordson Dexta Fuel Lines in reply to fatbob50, 10-03-2007 20:55:26
Do you know where I can get the right valve? Walt Allen
