Fordson Tractors Discussion Forum
Re: Super dexta pistons
El Toro
05-04-2007 05:16:47
You probably should've used a ridge reamer to remove the ridge at the top of the cylinder. Your piston rings are probably hitting that ridge.
You will probably need to use a little persuasion
or tap the piston back down into the sleeve and
use a ridge reamer. You can usually feel that ridge with your fingernails. Hal
