Fordson Tractors Discussion Forum
Re: Fordson Major Started Has Problems (long pos
R Wooley
04-06-2007 18:31:26
Sounds like Head Gasket most other problems would let water in oil. when you have the head off check sleeves they should be above the block .002 to .005 inches also the sleeves are sealed with "o" rings if you can determin which cylinder the gasket is bad on you may want to pull the sleeve. mine was run long enough to burn the "o"rings.
Good Luck my 56 backhoe has been a super workhorse
