Fordson Tractors Discussion Forum
Re: Cooling system problem on 1963FSM
Majorman
12-13-2005 09:20:50
A faulty cap could be the cause of your problem. So could over filling the radiator. If the tractor did not overheat,the water is not blowing out of the overflow all the time and the level is at the bottom of the filler neck, I would think that you do not have a problem.
If the water is being constantly blown out of the overflow even straight after starting, you have a head gasket failure.
Kenneth Armour
12-14-2005 09:43:59
 Re: Cooling system problem on 1963FSM in reply to Majorman, 12-13-2005 09:20:50
Hi Majorman:
Well I think my problem is solved.
I patched the little leak in the Rad. Refilled the system with new antifrezze again. I may have not had the right mix in it so I made sure I did a 50/50 mix this time.
I also installed an overflow bottle to catch any overflow.
Used the tractor today for about 1.5 hours clearing snow. There was a tiny bit of coolant in the overflow bottle, but otherwise everything seems to be working fine.
One funny thing is that I put a water temp gauge on the tractor, the capillary type, and it is not moving.
Does this mean My thermostat is opening too soon and the Engine is not reaching operating temp.
I put the old thermostat back in, and it was partially open when cold. So I suspect it is not working.
I will eventually order one from the UK.
Thanks alot again for the advice
Kenneth
Kenneth Armour
12-13-2005 13:13:37
Thanks alot for the advice majorman. I feel alot better.
Do you know what the poundage should be on the cap.
Kenneth
