Carburetor ICING Jerry/MT
Bob
12-31-2007 11:43:23
Jerry/MT,
Gotta disagree with your statement: "Fuel additives don"t help with carburetor icing. They only work to keep the water in the fuel bowl,tanks,and sediment bowls, low spots, etc from freezing and blocking the passages."
Fuel additives DO help, at least to a certain degree, with the internal icing in a carburetor that is the actual cause of poor running, as apposed to the visible ice on the OUTSIDE of the carburetor.
Jerry/MT
12-31-2007 12:17:09
 Re: Carburetor ICING Jerry/MT in reply to Bob, 12-31-2007 11:43:23
Bob,
I have to respectfully disagree. Having worked in the sircraft industry as a Propulsion Engineer during my professional career (34+ years), we would have loved for some type of carb anti-cing additive to be available to put in the fuel. (Chevron Research and others worked on this problem to no avail, unless there is something more recent that I am not aware of.)
The problem is that internmal carb icing is not caused by water in the fuel. It"s caused by ambient humidity the same thing that causes the external frost to form. The lowered static temperature that results from the high velocities in the carb plus the evaporative cooling of the fuel cool the metal well below ambient temperature.
The same type of icing (less the evaporative cooling effect of the fuel)is prevalent in the inlet and on blades and static structure near the compressor face of gas turbine engines and for the same reason; high ambient humidity. That"s why bleed air from warm parts of the compressor are ducted to the vanes and in some cases the spinners to preclude ice formation.
Water in the fuel is a whole other issue.
Bob
12-31-2007 22:28:07
 Re: Carburetor ICING Jerry/MT in reply to Jerry/MT, 12-31-2007 12:17:09
We ain't fly'in no planes here!
Jerry/MT
01-01-2008 11:36:53
 Re: Carburetor ICING Jerry/MT in reply to Bob, 12-31-2007 22:28:07
Have a Happy New Year!
