Posted by Steve@Advance on August 22, 2021 at 17:41:31 from (99.190.215.237):
In Reply to: Ford 841 update posted by grandpa Love on August 22, 2021 at 15:44:17:
If it still has the stock coil, the wire wires will work. Only with the flame thrower coils are resistor wires required, so I hear. But wire wires will not make it run bad, they are hard on the electronic unit.
Rapid, rhythmic popping back through the intake, worse under load or acceleration is usually caused by an exhaust valve not fully opening, a flat cam. Did you watch the valves opening while the cover was off?
It can also be cross firing, a carbon tracked distributor cap, really bad plug wire insulation between to wires touching each other, usually worse when damp.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
