Posted by Steve@Advance on August 01, 2014 at 20:24:53 from (107.203.134.67):
In Reply to: starter hang up posted by Indiana Mike 2 on August 01, 2014 at 18:04:04:
First, be sure the starter is not still trying to run, as in the switch linkage sticking.
Don't think shimming is going to fix it. But, just to be sure, pull the starter off and look at the wear pattern on the starter gear. See if the gear appears to be damaged from going too far into the flywheel gear. If it is, could be something up with the crank thrust bearing, letting the flywheel move too far forward, but let's not go there for now...
What's "supposed" to happen is, the gear spirals into the flywheel when the starter motor begins to spin. The gear remains in the flywheel gear until the engine starts. Even if the engine does not start, and you let off the switch, the gear remains engaged but not turning. Once the engine starts, the force of the turning flywheel gear spirals the starter drive out of engagement, back to the retracted position on the starter shaft.
If the starter drive looks good, feels good, ratchets out like it should, the spring and bolts are good, just oil the spline shaft and try it again. Sometimes slightly revving the engine will kick it out. If it still hangs up, try replacing the starter drive.
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
